Have a Tek TDS7404 on my bench for repair. Scope application hangs after loading Windows 98
Checking the console port, my initial findings were that the Dallas chip was bad:
romPost: PERFORMING NV-MEMORY WALKING-ONE TEST...
Expected Value: 0x00000001
Actual Value: 0x00000081
romPost: NV-MEMORY Walking-one test failed.
I replaced the DALLAS DS1245YP-100. The chip was a surface mount device, Digikey part # DS1245YP-100+
Battery was dead as well, so that was also replaced.
Now it (usually) boots OK, but the scope acts very strangely. Odd number-based .exe files were causing crashes in the \Windows\temp\ folder.
I suspected that there were one or more virus's on the scope. Sure enough, there was:
02/11/2016 02:38:44 PM,High,~2.exe (W32.HLLW.Nebiwo) detected by Virus scanner,Quarantined,Resolved - No Action Required,Threat Actions
performed: 1
02/11/2016 02:38:40 PM,High,~2306.exe (Backdoor.Sdbot) detected by Virus scanner,Quarantined,Resolved - No Action Required,Threat Actions
performed: 36
02/11/2016 02:38:35 PM,High,~719a.exe (Backdoor.Sdbot) detected by Virus scanner,Quarantined,Resolved - No Action Required,Threat Actions
performed: 54
02/11/2016 02:38:30 PM,High,~6376.exe (Backdoor.Litmus (2)) detected by Virus scanner,Quarantined,Resolved - No Action Required,Threat Actions
performed: 32
02/11/2016 02:38:26 PM,High,~00d7.exe (Backdoor.Litmus (2)) detected by Virus scanner,Quarantined,Resolved - No Action Required,Threat Actions
performed: 49
03/06/2015 01:11:42 PM,High,ophcrack-win32-installer-3.6.0.exe (Pwdump) detected by Auto-Protect,Quarantined,Resolved - No Action
Required,Threat Actions performed: 1
11/01/2014 07:04:49 AM,High,wfps08beta.exe (Trojan.ADH) detected by Virus scanner,Quarantined,Resolved - No Action Required,Threat Actions
performed: 1
10/01/2014 03:03:23 PM,High,Trojan.Gen.2 detected by Virus scanner,Quarantined,Resolved - No Action Required,Threat Actions performed: 1
07/21/2014 08:52:08 AM,High,a0156429.exe (Trojan.ADH.2) detected by Auto-Protect,Quarantined,Resolved - No Action Required,Threat Actions
performed: 2
07/21/2014 08:52:08 AM,High,a0156428.exe (Infostealer.Bucuper) detected by Auto-Protect,Quarantined,Resolved - No Action Required,Threat
07/21/2014 05:27:22 AM,High,ofertacoloors_looksafe.exe (Trojan.ADH.2) detected by Virus scanner,Quarantined,Resolved - No Action
Required,Threat Actions performed: 4
07/21/2014 05:27:10 AM,High,ofertacloud_backup_setup.exe (Infostealer.Bucuper) detected by Virus scanner,Quarantined,Resolved - No Action
Required,Threat Actions performed: 2
05/03/2014 08:17:41 AM,Medium,tw562.exe (WS.Reputation.1) detected by Download Insight,Quarantined,Resolved - No Action Required,Threat
10/25/2013 01:24:04 PM,High,gjsphwzf.exe.part (Suspicious.Cloud.9) detected by Download Insight,Quarantined,Resolved - No Action
Required,Threat Actions performed: 1Rather than trying to fight these nasty little things, I re-imaged the hard drive with a clean known-good image.
Now it's up and running and passes SPC and self tests from the utility menu. No more crashes.
However, the last remaining problem is that about 1 in 10 attempts to power up the unit, the PPC board will hang like so:
UUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU
romPost: MPC106 Walking-one passed.
romPost: MPC106 configuration passed.
romPost: First PCI access passed.
romPost: PC87560 Walking-one passed.
romPost: PC87560 configuration passed.
romPost: DEC21554 configuration passed.
romPost: PERFORMING ROM CHECKSUM TEST...
romPost: ROM checksum passed.
romPost: PERFORMING DRAM CELL TEST...
romPost: Enabling data cache...
romPost: Data cache enabled.
romPost: Enabling instruction cache...
romPost: Instruction cache enabled.
romPost: DRAM Cell test passed.
romPost: Disabling data Cache...
romPost: Data cache disabled.
romPost: Disabling instruction cache...
romPost: Instruction cache disabled.
romPost: PERFORMING DRAM MARCH TEST WITH CACHE OFF...
romPost: Writing address to each *address...
romPost: Reading address from each *address...
romPost: DRAM march test passed...
romPost: PERFORMING DRAM MARCH TEST WITH CACHE ON...
romPost: PERFORMING DRAM WALKING-ONE TEST...
romPost: DRAM Walking-one test passed.
romPost: NV-MEMORY Walking-one test passed.
romPost: POWER-UP DIAGNOSTIC COMPLETE.
VxWorks System Boot
Copyright 1984-1996 Wind River Systems, Inc.
CPU: Tektronix HPP - PowerPC 740
Version: 5.3.1
BSP version: 1.0.4.0
Creation date: Nov 2 2000, 11:03:34
Press any key to stop auto-boot...
1 0
auto-booting...
boot device : sm
processor number : 0
file name : c:/vxboot/vxWorks.st
inet on backplane (b): 192.168.0.1:ffffff00
host inet (h) : 192.168.0.2
gateway inet (g) : 192.168.0.1
flags (f) : 0x1008
target name (tn) : tds7000
startup script (s) : c:/vxboot/topscript.hw
Initializing backplane net with anchor at 0x1e80000... done.
Backplane anchor at 0x1e80000... Attaching network interface sm0... done
done.
Attaching networkPC1 dio device driver installed
interface lo0... done.
Attaching DIO client... done.
Loading c:/vxboot/vxWorks.st...1773516
Starting at 0x200000...
Host Name: bootHost
User: target
Initializing backplane net with anchor at 0x16e0000... done.
Backplane anchor at 0x16e0000... Attaching network interface sm0... done
done.
Attaching network interface lo0... done.
Adding 6008
It always have exactly at this point. Right after the 6008.
It should look like this:
Adding 6008 symbols for standalone.
]]]]]]]]]]] ]]]] ]]]]]]]]]] ]] ]]]] (R)
]]]]]]]]]]]]]]]]]]]]]]]]]]]]] Development System
]]]]]]]]]]]]]]]]]]]]]]]]]]] VxWorks version 5.3.1
]]]]]]]]]]]]]]]]]]]]]]]]]] KERNEL: WIND version 2.5
]]]]]]]]]]]]]]]]]]]]]]]]] Copyright Wind River Systems, Inc., 1984-1997
CPU: Tektronix HPP - PowerPC 740. Processor #0.
Memory Size: 0x2000000. BSP version 1.0.8.0 .
WDB: Ready.
KERNEL: THERMAL CONTROL INITIATED
Executing startup script c:/vxboot/topscript.hw ...
Once it boots it'll run for hours on end with no issues.
Currently, I'm running the scope with the PPC memory and NLX motherboard's memory located on the NLX board. This is allowing me to run Memtest86+ 5.01 on both DIMM modules - so far Memtest has completed one pass with no errors.
Any ideas or thoughts are much appreciated.
Jay
