Author Topic: [SOLVED]Tek TDS744A slow refresh or recovery  (Read 2822 times)
Offline DaxxinTopic starter
« on: February 14, 2018, 07:21:24 pm »
applyng signal or changing channel very very slow to refresh even with the input disconnected remai sine trace on the screen to refresh need to
change trigger channel or rotare h or v , look like something wrong with video ram, sometime slow but recover sometime not like ch3 in the video.-
never own scope like this before but i guess its not regular.
look at the video.
https://youtu.be/QaDCtnPcZgU
« Last Edit: February 20, 2018, 08:10:06 pm by Daxxin »
Offline Jwalling
  • This is work?
Re: Tek TDS744A slow refresh or recovery
« Reply #1 on: February 15, 2018, 10:45:00 am »
I suspect it's because you are using ET sampling *and* averaging. Save the setup and post it here and I'll try it on a TDS784A.
Jay
System error. Strike any user to continue.
« Reply #2 on: February 15, 2018, 06:21:20 pm »
Hi Jwalling , here the setup i will try to different set  , here setup attached
Offline Jwalling
  • This is work?
« Reply #3 on: February 16, 2018, 12:35:52 pm »
The only difference I noted is that when I inputted the signal to CH3, then set the trigger to CH3 (From CH1) the signal resolved quickly, where yours seems to sort of fade in but never looks very good. Have you run the full self test from the utility menu as well as SPC?
Jay
« Reply #4 on: February 16, 2018, 06:23:12 pm »
Your right i get processor error with the test with following gpib log
ERROR: diagnostic test failure, dsp68kD1MemTest, ** addr = 0x720a680  exp data = 0x5555  actual = 0xff55, ** addr = 0x720a682  exp data = 0x5555  actual = 0xff55, ** addr = 0x720a684  exp data = 0x5555  actual = 0xff55, ** addr = 0x720a686  exp data = 0x5555  actual = 0xfd55, ** addr = 0x720a688  exp data = 0x5555  actual = 0xff55, ** addr = 0x720a68a  exp data = 0x5555  actual = 0xff55, ** addr = 0x720a68c  exp data = 0x5555  actual = 0xfd55, ** addr = 0x720a68e  exp data = 0x5555  actual = 0xfd55"
Offline Jwalling
  • This is work?
« Reply #5 on: February 17, 2018, 11:19:16 am »
I have a few failures in my logs that may be of some use. These were pulled from the console port.
U1009-17 shorted to VCC:
dsp68kMemTest .................. ***FAIL***
..error details:
ERRORID: 153 diagnostic test failure dsp68kD1MemTest
** addr = 0x7200000  exp data = 0xf7ff  actual = 0xffff
and
U1009-17 SRAM open etch:
..error details:
So maybe that memory chip or associated circuitry. U1008 may also be suspect.
« Last Edit: February 17, 2018, 11:22:17 am by Jwalling »
Jay
« Reply #6 on: February 18, 2018, 11:35:16 am »
thanks for sharing the info , its ok to replace with AS6C1008-55SIN?
i seen have 2 additional not populated sram expansion U2008 and U2009 , theres benefits to install also them?
Offline Jwalling
  • This is work?
« Reply #7 on: February 18, 2018, 12:17:58 pm »
That seems like a suitable replacement, but I'm not saying that one of the chips is defective. It could be some other device that's associated with the circuit.
I would not install memory where none ever existed in the first place.
Jay
Offline andy2000
« Reply #8 on: February 18, 2018, 04:45:43 pm »
Start by checking for broken solder connections.  I had a 744A that developed some bad connections around the large memory controllers which caused memory errors.
« Reply #9 on: February 18, 2018, 08:17:50 pm »
 ::) i'm too late reading yours replies..  i have 2 M5M51008 but 100ns instead 70ns replaced alredy , well before the test very short (run 30 seconds without any graphical shapes tests) then i was getting
processor fail , now seems the test is running very long then at the end i'm getting the banner instead the result and the scope freeze stucking on the banner , do you think slower sram can cause this?
by the way ordered alredy the correct sram.
« Last Edit: February 18, 2018, 08:20:22 pm by Daxxin »
Offline Jwalling
  • This is work?
« Reply #10 on: February 19, 2018, 11:10:47 am »
Is switch 3 on the dip switch set on or off?
Jay
« Reply #11 on: February 19, 2018, 06:12:25 pm »
this the actual dip switch positions
Offline Jwalling
  • This is work?
« Reply #12 on: February 19, 2018, 06:31:51 pm »
Then it sounds like something happened when you replaced the chips. Could be that the access time is too slow, or a damaged trace from the removal process.
Jay
Re: [SOLVED]Tek TDS744A slow refresh or recovery
« Reply #13 on: February 20, 2018, 08:12:24 pm »
Replaced with 2 new 55ns M5M51008 everything fine thanks Jwalling for the inputs was a big big help , i will post video soon  :-+ , very fast now changing settings from front panel.
Offline Jwalling
  • This is work?
« Reply #14 on: February 21, 2018, 10:47:23 am »
You're welcome!
Jay
