Author Topic: Tek THS720 BNC replacement  (Read 661 times)
Offline 1audioTopic starter
« on: July 26, 2021, 10:57:27 pm »
The THS series of handheld scopes use BNC's with plastic barrels that are fragile. I have one that was abused with the P6015 probe to the point where the connector is quite intermittent. These are odd BNC's. I would like to get replacements that are correct if they can be had. Otherwise I'll just mount a pair of generic isolated BNC's. Does anyone know a source?
Also a source the the "stand" in the back which is missing?
Online giovannirat
  • Country: at
Re: Tek THS720 BNC replacement
« Reply #1 on: July 30, 2021, 07:40:18 pm »
« Reply #2 on: July 31, 2021, 04:39:57 am »
Thanks for the tip. They are cheap enough that i'll give them a try. I have also found some other options which I'll share when I see if they can work.
