Author Topic: TEK2213a Service Manual  (Read 2610 times)
Offline tkamiyaTopic starter
« on: June 15, 2018, 07:27:45 pm »
Can someone point me to a SERVICE Manual for Tektronix 2213A?  It has to be the A version.
I found an user's manual but not the service manual.  Thank you.
Offline cheeseit
Re: TEK2213a Service Manual
« Reply #1 on: June 15, 2018, 10:01:59 pm »
I searched the usual places and googled a bit as I'm sure you have too but no dice. ArtekManuals has it.
Edit: I meant searched for one that was free to no avail, then checked Artek  ;)
« Last Edit: June 15, 2018, 10:08:32 pm by cheeseit »
Offline David Hess
  • DavidH
« Reply #2 on: June 16, 2018, 10:44:26 am »
Except for the dual delayed sweep, the 2215A is the same oscilloscope so the 2215A service manual can be used.
Offline Radio Tech
  • KC4UMO Buddy
    • Hobby Forum
« Reply #3 on: June 16, 2018, 10:54:33 am »
You have to sign up but is free.
http://ebaman.com/
files>electronics>scope>tektronix>2xxx second page at the top
« Reply #4 on: June 16, 2018, 09:32:34 pm »
Thanks.
Yes, I found one at ArtekManuals but I was looking for a free one.  Maybe I shouldn't be so cheap.
With information that 2215A is essentially the same, I found the portion I was looking for.
Thank you very very much.
My scope collection is multiplying!
Offline Chris56000
« Reply #5 on: June 20, 2018, 06:20:06 pm »
Hi!
https://www.dropbox.com/s/3w6jp7qd75v5u2g/Tek%2B2213A%2BOscilloscope%2Bebaman.pdf?dl=0
I found I had no problems reading any of it!
Chris Williams
It's an enigma that's what it is!! This thing's not fixed because it doesn't want to be fixed!!
