Hi guys, I'm looking for advice.
During a delivery of the oscilloscope, the BNC connector AUX Trigger Input was mechanically damaged. The connector was crushed and cracked during the repair process. Some brittle alloy is used.
I know it's not a very important connector, but it bothers me.
Inside the scope this is a cable assembly BNC-SMB with a special metal cable (I do not know the type), although the connector itself is the most common.
Probably the length of this cable assembly is also important.
I'm thinking of trying to solder the cracks and buff the surface or replace the whole cable assembly, but I'm not sure about the length and the right materials.
What is your advice?
