Author Topic: Fixing an old Voltcraft VC 650  (Read 21061 times)
Offline kardacz
Re: Fixing an old Voltcraft VC 650
« Reply #50 on: January 14, 2016, 06:18:39 pm »
Good evening; on this same model of multimeter, the Integrated Circuit: KS57C2616 (or WENS50) should you it be programmed by software for the multimeter works ??? |O
Offline retiredcaps
« Reply #51 on: January 14, 2016, 06:37:33 pm »
I'm not sure what you are asking.  What is not working?  Can you measure a simple 9V battery?
Offline kardacz
« Reply #52 on: January 14, 2016, 06:58:47 pm »
Merçi have already answered. On my multimeter (vc650), the leading integrated circuitry was dead, he warmed the multimeter showed: OL and its consumption was 300 mA !! (Origin: WENS50), I was able to download the schema (even on this forum), and they put KS57C2616 .... I now put the new Integrated Circuit (I verified the magnifying lamp the state of the welds). But the problem is that it does not turn on. Therefore you must reprogram it with software, or there's some other explanation you there ???
Offline kardacz
« Reply #53 on: January 15, 2016, 05:12:20 pm »
oops! Nobody has the answer ??
Offline kardacz
« Reply #54 on: October 25, 2016, 12:22:06 pm »
Hello; replace 2 Integrated Circuits NJU4066 because the fuse has not played its role (rolled aluminum), and these components are destroyed!
