I have a Tek 2246 I've been working on for few months, on and off.
This scope works fine with exception on one thing. Channel 2 acts out after few minutes from cold start. The trace goes up and down by about 1 unit on graticule, sometimes slowly, sometimes quickly. Sometimes it almost forms a wave form. The behavior does not change with voltage divider setting or horizontal sweep setting. (of course, scan speed changes but vertical movement stays the same) On Ch2, I can actually make measurements and they are accurate. It's just that it acts like its ground is floating. It behaves the same with input grounded as well.
I've replaced a vertical control pot on the front screen. Cold sprayed everywhere. Tapped everything with back of screw driver. Nothing I did changed behavior. It is acting as if there is a cold solder joint or intermittent connection somewhere but I am unable to find it.
If anyone has any ideas, I'd be thankful of hearing about it.
