Does anyone have a datasheet or manual for the Tektronix 011-0099-00 5W 50ohm termination? I tried looking but couldn't find anything. I was curious about the bandwidth and pulse power capability.
Also, has anyone attempted to replace the BNC connectors? The female connector on one of my terminators looks like it should be replaced. The connector on the left has a pretty loose center contact when compared to the one on the right.
I assume, that to put this together, the termination resistor is soldered directly to the female connector with some sort of leaf spring assembly used to touch the inner shell, then the male pin is soldered onto the other end and it just free spins as the female end is threaded into the housing. I guess Tektronix could have used a coaxial resistor. Most just use SMD parts soldered between the center pin and a leaf spring touching the shell.
Any thoughts on this? Maybe the expanded female contacts aren't as big a deal as I'm making them out to be?
