Hi Everyone!
(X-Post between EEVBlog and TekScopes@groups.io.)
I recently picked up a Tektronix 2213 from my local electronics recycler but unfortunately it is non-functional. Just in advance I want to let everyone know that this is my first time working with an analog oscilloscope, and one of few times working with any oscilloscope at all - My goal is to hopefully repair it and use it as my daily driver.
As of this minute, the 2213’s horizontal sweep does not seem to work correctly, taking up less than half of the screen and centered to the left side (I will post photos once my phone is charged). This is paired with a very odd signal coming through on both channels (Very remotely similar to this person’s scope
). This could be interference but it is still odd nonetheless. When the volts/div and the sec/div is increased (counter-clockwise), I am able to view the test frequency reasonably okay, but it actually shows up smushed on the right side. Also, when moving the position of either channel, it moves in a bit of a bell curve (to the left), and the horizontal position dial causes what’s shown on the CRT to shrink (or completely cut off occasionally).
I have already opened it up to find a replacement cap installed (albeit somewhat poorly with noticeable burn marks from a soldering iron) on C849, one leg of which is bent to connect to a resistor and the other connected to ground(in accordance to diagram 6).
Taking a look at the voltage test points, everything was in tolerance ALTHOUGH the resistance on +30 and +100 (if I recall, will need to double check) while being disconnected from mains (I don’t have an isolation transformer) was significantly lower than what the service manual described. I have already taken a look at the caps within the scope and under the shield, and none have leaked or blown, but I haven’t replaced them just yet (or the EMI filter) as I need to compile a list of them and I wanted to see if I could get the scope semi-functional beforehand.
Before someone goes off on me saying I didn’t set it up correctly, I did in accordance with the operators manual AS WELL as the service manual when going over testing procedures. I could still not have done anything correctly, but with the plethora of issues I am facing I really doubt that my misconfiguration is the cause of all issues. I also haven’t changed anything calibration related within the scope (just yet…) because I didn’t want to screw anything up more or make it harder for myself in the future.
If anyone has an idea of what is going on, tips / suggestions, really anything - That would be great!
Thank you very much!
EDIT: When I was just shutting it down right now, I noticed one of the neon lamps (DS868 I think?) light up and flicker out when I pressed the power button to turn it off. I found this little bit in the service manual but I don't know if that could pertain to the issue I am facing:
Neon lamps 0S867 and DS868 protect the crt from
excessive grid-to-cathode voltage if the potential on either
the control grid or the cathode is lost for any reason.
I guess potential is "being lost" on shutdown so nothing to worry about? Will have to take a closer look though.
