I'll stick my neck out here because this might be similar to the same issue I had with a Sencore SC61 Waveform Analyzer.
In the calibration instructions, both channels were adjusted individually to the center graticule line.
Next, the A+B button would be depressed.
If the traces didn't remain together on the center graticule line, a variable resistor needed to be adjusted on the Vertical Amplifier Board.
Maybe it's the same for a Tektronix scope
