After looking at schematics, check the following transistors:
Q732
Q737
Q742
Q743
They amplify the X-axis signal from CH1.
Don't pull them out. Use another scope to trace the signal from CH1 in X-Y mode. Follow the schematic on page 159 here https://w140.com/tekwiki/images/e/e5/070-4733-00.pdf
Follow the signal until it looks "wrong", maybe the wave is cut in half, or it's out of phase.
So.. I was looking for those Tranny's that you stated.
AND THEN I SAW THIS and then i looked closer with my video microscope
41 - is what i spotted first
42 - a bit of a closer look
33 and 34 are video scope views
so... We have CRACKED JOINTS
I sucked up the old solder with Solder wick and Re Soldered the Joints
then restarted the scope, still get the same result, XY Still doesn't work,
But YT Does
I've also noticed that If i feed in a Signal (say sine wave) 1kHz that's fine, But given this is a 60MHz scope.
i should be able to feed in up to 60MHz and still be able to stretch out the signal (or.. Zoom in) and be able to easily see the waveform,
However i can't. Even at 10MHz you can't zoom in and see the waveform as a single AC Line.
