So should I just leave it alone calibrate it as is a move on?
Oh, how do I answer that?
It depends on your skill level and risk versus reward. High skill lowers the risk of damaging the instrument. If you have alternative instrument like another similar or better oscilloscope, then the risk is also lower that you will be left without any oscilloscope.
Complicating this decision is that there may be some risk to allowing the aluminum electrolytic capacitors to wear out. 2235 series power supplies seem to have a failure mode which might be brought on by worn out aluminum electrolytic capacitors. I suspect this but do not know and cannot prove it yet.
I would not mess with it unless you decide to change the aluminum electrolytic capacitors and if you do that, then I recommend changing the RIFA capacitors and the focus chain resistors. The later two are not worth bothering with otherwise.
