This one has been bothering me for weeks on end.
I have an old Tektronix 2213A scope that I'm trying to repair. The second time I powered it on after having had it sit in my storage room for a long time, the fuse blew. I didn't have any 1A slow-blow handy, so I just put in a 2A one. Bad idea! The fuse blew, again, and with it an unknown amount of circuitry in the power supply.
Here is the service manual for the Tek 2215A, which has an identical power supply to the 2213A:
http://www.ko4bb.com/manuals/129.241.229.7/Tek_2215A_Service.pdfScrolling to page 180 (as seen by the PDF reader), we find the power supply schematic.
This guy has provided us with some troubleshooting tips:
http://www.hakanh.com/dl/docs/troubleshooting_tips_on_2200_ps.pdfCR907 was shorted and badly burned, so I swapped it out with a new one. Put a new 1A slow-blow fuse in, it blew. Then I checked all the other components he mention. For some reason, R909 had way higher resistance than 39 ohms. The color code said 39 ohms, the meter said many kiloohms no matter how hard I rubbed the probes against its legs.That got swapped with a new one. I swapped out U930 for good measure, and either CR908 or CR920. Unfortunately, I can't remember which. It was an avalance diode I believe.
Turns out, the reason the fuse blew now was because rectifier diodes CR902 and CR904 were shorted. So I went and switched all four rectifier diodes with new 1N4007's. No life, not even a blown fuse.
I desoldered C925 and found that it looked bulged on the bottom. So I went and picked up an ELNA cap with the right specs. Still no life.
There is more than 300 volts across C906, so everything before that is likely OK. When I apply 43VDC to test points TP940 and TP950 with Q9070 disconnected, the scope works exactly as it should. So the problem must be between the diode bridge and the test points. I was not able to power U930 and check the waveforms tonight. I will also take Q9070 for a spin on my Tektronix 577 curve tracer sometime soon.
Originally, Q9070 was an MTP6N55, which even had a hole punched through it when it exploded, but I couldn't get it anywhere. So I bought an IRF820 in the hope that it would work. This could be the problem. I won't know until I put it on the curve tracer. I have still to check the windings on T906. If any one of these is not the answer, I just don't know what else could be.
Do you have any suggestions? The circuit took a pretty good load when I ran it with the 2A fuse. I suspect that's when the rectifier diodes died.
At least I learned that there's a good reason one should not use a heavier fuse than specified.
