I have this unit. It was given to me. I replaced the power switch, the main 470 ohm capacitor and the main fuse. I have extras of these parts.
I found the exact switch in some other kind of a mount. I disassembled it from that mount and then I could use it in the 2215. I can take the mount off of my extra, for you; see below.
I made sure to get a high quality cap. I found an Ebay/USA Seller that had Panasonics. Great guy, he even proofed them for me, to be really close on Ferad. They came in a lot. I used the one closest to 470 ohms. The remainder that I have to share were spec'd at 480. I have no idea of how old they are, but mine works.
The fuse is an AGC 2a/250v. I have one extra to share, but you should be able to source these, with little problem.
All that said to say that if you need any of these items, we can work it out. I wasn't sure where you ended up with the switch. Yes, you have to dig in there to get to it, but it is replaceable. IIRC, I managed it, without removing the board - but, don't hold me to that... If you want anything, send me a private message. Maybe we can work a friendly trade, or you can cover my costs.
