This is my very first post on this forum, so forgive me if this as been asked before, or if this is not the right place to ask these questions.
I picked up 2 Tektronix osciloscopes yesterday for a very fair price. A 2335 and a 2215 (not 2215A).
Not the main issue is with the 2215.
Everything seems to work fine, the display is fine and bright, no dead spots or anything (on both).
These are the first osciloscopes that I ever owned. But I’ve used many.
That being said, I notice that the 500mV/1Khz calibration square wave On the 2215 is not showing a neat square wave at all.
The « walls » are not straight. The waveform looks slightly like a pyramid. Meaning that the if you take the positive portion, it is narrower than negative at the top. Not my much, but it’s clearly visible. I’ve tried everything I know to correct it, but it just won’t let me.
Now I don’t know if this is the generated signal that is « defective », or something else.
I should be receiving my new frequency generator soon, and compare.
Of course I have calibrated the probes.
Any ideas as to what this could be due to? Is there a inside trim pot to adjust it maybe?
I also was thinking of replacing all the electrolytic caps in the power supply. I noticed a 2x70Mfd 450V can capacitor.
I measured the voltages across, and I have about 320-ish V. I have 2 100Mfd 400V caps. Unless there is a spike when powering up, I assume it’ll be safe to use them, correct?
PS: Does Someone know where I can find schematics for these 2 units?
Thank you for your help.
