Author Topic: Tektronix 2215 repair project.  (Read 3997 times)
Offline Six_ShooterTopic starter
« on: December 01, 2013, 02:36:41 am »
I have recently received a non-operational Tektronix 2215 O'scope.
I've found a couple of things so far, one being an item I can't fully identify, because I'm not familiar with the schematic symbol.
From the Service Manual I have that it is "LAMP,GLOW:90V,0.3MA"
I have tried to find this on Digi-Key, Mouser, Jameco, Futurlec, Goldmine Electronics, and a few other sites but have not found a match.
Any help with finding a suitable replacement, or using others in series would be the same?
If someone could look at the schematic and let me know. I will also attach a picture of the item.
Offline vk6zgo
Re: Tektronix 2215 repair project.
« Reply #1 on: December 01, 2013, 03:08:28 am »
It is a small neon bulb------they commonly fire at 90 volts.
Tektronix use a lot of them--often they are only "on" under fault conditions.
Not sure about in your case.
Online N2IXK
« Reply #2 on: December 01, 2013, 03:16:11 am »
Sounds like a standard NE-2 (A1A) neon lamp to me...
http://www.digikey.com/product-detail/en/A1A/A1A-ND/4176016
http://www.mouser.com/ProductDetail/Chicago-Miniature/A1A/?qs=sGAEpiMZZMucm%2f%252bFOY0TQhPZClhLEOAyzHNdSZM1TUs%3d
http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_27351_-1
From what I can see of your circuit, I don't think these lamps are going to cause a non-operational issue. They look like they are used as overvoltage protection devices, to protect the Z-axis driver transistors from high voltage breakdown in case of a transient arc inside the CRT. They most likely never light unless the CRT or other component arcs over.  The broken one should be replaced, though...
« Last Edit: December 01, 2013, 03:42:49 am by N2IXK »
"My favorite programming language is...SOLDER!"--Robert A. Pease
« Reply #3 on: December 01, 2013, 03:59:11 am »
I agree, I don't think this is going to cause a non-operational issue, but I would like all of the known issues to be fixed before looking any (or much) deeper.
I have also found a broken leg on a MOSFET that I will be replacing, or at the very least re-attaching the MOSFET leg.
There's an area on the bottom of the main board that is browned that I have a feeling I should inspect a little closer on the top side, unfortunately this area is under three stacked boards that holds all of the front panel controls.
Thanks for the links, I'll take a look at them a little deeper at them and figure exactly what part numbers to order. I didn't seem to be able to locate them through the search engines earlier.
