Ok so i took screenshots of pins 15 to 20.
Can't really make the scope show anything more than that but maybe it will be enough to give some ideas.
Also you can see some flat spots in the signal in some screenshots, these flat spots are present on all pins that show a signal but are hard to catch for a screenshot.
15 - LCD_TXBOUT2-
16 - LCD_TXBOUT2+
17 - LCD_TXBOUT1+
18 - LCD_TXBOUT1-
19 - LCD_TXBOUT0+
20 - LCD_TXBOUT0-
500us/div?
These signals are in the hundreds of MHz range (i.e. edge-to-edge times are only a few ns), even 500ns/div is too slow to see much of anything...
If your two schematics are the right ones, I'm surprised you even got it to display anything at all because the pinouts are almost completely different, and the LVDS lanes don't even match (not even the clock.)
13 CLK+ OUT0-
14 CLK- OUT0+
15 OUT2- GND
16 OUT2+ OUT1-
17 OUT1+ OUT1+
18 OUT1- GND
19 OUT0+ OUT2-
20 OUT0- OUT2+
21 GND GND
22 USBDM CLK-
23 USBDP CLK+
And I'm pretty sure if it had a webcam it's fried now, with the full system DCBATOUT being applied to the 3V and USB lines...
