Looks like the preregulator in the 2235.
Should produce 43 volts at 1 amp to the power supply inverter(Q 944, 946 & 947, T 944 & 948), which can be provided with an external DC power supply to TP 940.
If current is too high (as continuously tested across the 0.2 ohm resistor) it will shut down and restart repeatedly, chirp, chirp, chirp.
Over voltage will trip the SCR crowbar (Q 935), over current load with the same effect.
Be careful with this circuit, as there are no valid earth potential points so a scope ground cannot be connected unless the AC supply is provided through an isolation transformer.
Download the preregulator trouble shooting guide from the manual
https://w140.com/tekwiki/wiki/2221
