Author Topic: Tektronix 222/224 Portable scope CRT pinout? Picture request.  (Read 1297 times)
Offline TERRA OperativeTopic starter
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
So I had a bit of a problem crop up while restoring a Tektronix 224 scope...
While removing the CRT, the plug housing came apart and all the pins fell out and I don't know what order they go back in.  |O
Is there anyone who has a Tek 222 or 224 portable scope who can pop the cover off and take a few photos?
I know what pin numbers each wire is supposed to be for, but I don't know what the actual pin numbering is on the tube itself to match to the wires.
Any help would be awesome :)
Offline jdragoset
Re: Tektronix 222/224 Portable scope CRT pinout? Picture request.
« Reply #1 on: March 21, 2019, 01:21:14 pm »
Here are some Pix taken this AM.
There is a single white wire in the dielectric shield at about 1:30, unused pin/space on either side, probably anode or focus if anode has its own HV connector near the screen.
Numbering starts just past 3:00 with a brown stripe in gray jacket and proceeds clockwise, red, orange ... to gray stripe before the unused pin/space back to white.
I did not remove the socket from the CRT.
I can send more if needed.
Jim
  • Country: jp
« Reply #2 on: March 21, 2019, 02:35:24 pm »
Awesome, thanks for the help :)
I found some pics, but this helps confirm I got it correct.
Scope CRT is now back up and working again. :)
Here's the pinout attached below if anyone else happens to be looking for it in the future.
« Last Edit: March 21, 2019, 03:03:57 pm by TERRA Operative »
Offline xxx2fan
« Reply #3 on: June 07, 2019, 10:43:30 pm »
Try this link it should help you.
http://w140.com/tekwiki/wiki/Main_Page
xxx2fan
