Hey all, this is my first post on EEV blog.
Just received a Tektronix 2230. Seems to be working as I'd expect (for the most part). I'm really liking it so far but do have a few questions. This is my second scope - I don't know much about them but love to tinker with them and use them with my guitar amps / pedals.
1. One thing I've noticed is that the display comes off a little bit stroby. It's not super noticeable but a little bit pesky is how I'd describe it. The reason it caught my eye is my older Leader LBO-520A has a super clean / smooth display. But with the 2230, it's like you can see the leading edge of the sine wave each time it sweeps instead of it being a very smooth / single contiguous line. Is that just normal for this type of scope? This is when it's in its "analog" mode - as soon as it creates a digital image, it's no longer like that.
2. While researching the above point, I stumbled onto this thread:
https://www.eevblog.com/forum/repair/dark-spaces-on-the-traces-of-tektronix-2230-oscilloscope/. The black dots described in that thread are sort of like what I'm experiencing. I decided to check out the RIFA caps as recommended in that thread since the issue was sort of similar. From a visual standpoint, the caps look fine. Should I change them anyway?
3. Since I'm inside, is there anything else recommended that I should do / check out? I plan on spraying some air to clean it out and spraying Deoxit on the mechancal pots, etc.
4. Also related to the above-mentioned thread, tggzzz mentions turning annotations off to help in that specific situation but I'm wondering if that may help me as well. I have no idea what the annotations are / how to disable them - I assume this is something I should do in the menu? If anyone can advise me what these are and where to access, that would be great.
Thank you guys and excited to join the forum! I really love tinkering with scopes and electronics.
Tommy
