As described here
https://www.eevblog.com/forum/repair/tektronix-2230-scope-mechanical-parts/msg4529390/#msg4529390 I became owner of a poor Tek 2230 that undergo a moron's attempt to "repair" it. Its PSU was blown, not the tiniest sign of life in there. The numbskull who massacred it had installed a 5A fuse, adding further damage to initial failure.
It took a fair amount of hours and a lot of head scratching but it ended in a successfull repair. Some pictures here :
https://photos.app.goo.gl/8B4YyACh2ZtfrG8d9I had to replace : CR90, CR907, Q9070, Q908, U930, CR908, R909, R908, C904. Given the dreadful access to those parts it has been the worst experiment I had since many years, but I'm very happy with the result.
Something worries me with the way Tektronix designed the PSU: the value of the C906 (75µF) located after the full-wave rectification, is the image of the energy supplied by the power supply. The more the voltage supplied by the rectifier increases, the more the value of the capacitor decreases to supply the same energy and therefore the same power. Under 220V, it will provide four times more energy, which can cause Q9070 to explode in the event of a malfunction or a voltage spike, or a parasite on the mains network.
Q = C x U in coulombs (Quantity of electricity)
E = 1/2 C x U² in joules (Energy)
which gives :
- with mains voltage = 110 V : E = 1/2 x 75 10 -6 x 110 ² = 0,45 J
- with mains voltage = 220 V : E = 1/2 x 75 10 -6 x 220 ² =
1,8 J that's enormous
I might be worrying for nothing though, but I'm tempted to power the scope through a 220/110V transformer.
I now have to find an elegant solution to fix what the moron did with his Dremel :
https://photos.app.goo.gl/8B4YyACh2ZtfrG8d9Thanks for your attention.
