Author Topic: Tektronix 2235 Horizontal problem  (Read 2006 times)
Offline buck converterTopic starter
« on: August 31, 2017, 09:48:09 pm »
Recently acquired a tektronix 2235 from a local university. I am not sure if what I recorded is normal.
In these two videos I recorded the edge of the probe compensation square wave. I. The first one the x10 mag is activated.
https://youtu.be/v6NTnEvhzTM
https://youtu.be/DcQEsyPuBJY
Here is XY mode. I can only adjust the x position a little bit but y goes across the screen.
https://youtu.be/lmHDz2LqZu4
I have a proper soldering iron and another analog oscilloscope that could be used to fix this but I do not have an isolation transformer, nor do I have any formal EE education (I'm in high school), so I probably can't do more than to tune knobs, check power supply voltages and replace capacitors. :-//
Just me and my scope.
Offline Armadillo
Re: Tektronix 2235 Horizontal problem
« Reply #1 on: August 31, 2017, 10:11:01 pm »
You need to have input on both X and Y. Read the manual.
