Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Tektronix 2235 issue
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Tektronix 2235 issue (Read 1035 times)
belzrebuth
Frequent Contributor
Country:
on:
September 26, 2019, 01:35:37 pm »
I was trying to troubleshoot a function gen (3312A) and after a while I realised that it was actually my scope that had the problem not the generator.
The issue is that square waves of about 10kHz and on are showing like in the attached picture.(10kHz square and 100kHz square generated by a rigol dg1022z)
The problem affects both channels so it should be probably before the input section.
Although it's now showing at the pictures I'm using standard 50ohm bnc cables so it's not a probe problem.
The scope used to work fine because I specifically remember viewing waveforms in the upper kHz range with no problems but as I mostly work with audio this problem can be easily over six months old without me noticing.
Last Edit: September 26, 2019, 01:40:23 pm by belzrebuth
Logged
mzacharias
Country:
Re: Tektronix 2235 issue
Reply #1 on:
September 26, 2019, 04:26:33 pm »
"Thou Shalt Check Power Supplies"
Logged
belzrebuth
Country:
Reply #2 on:
September 26, 2019, 05:24:01 pm »
DC Voltages are within spec. (5.2V is a little low at 5.08 but still within spec)
Tested as per the service manual instructs on pg 5-4.
Seems like CH2 is different than CH1.
Here's what a 20kHz square looks like on CH1 vs CH2.
edit: Should I mess with the attenuator compensation capacitors for each channel?
The scope seems in a good working order overall so I don't want to mess with its calibration setting unless absolutely necessary.
I mean I could maybe make the problem go away if I tinker with the adjustment capacitors but if there's an actual fault there I may need to calibrate it all over again..
Last Edit: September 26, 2019, 07:26:37 pm by belzrebuth
Logged
rf+tech
Country:
Real radios are olive drab
Reply #3 on:
September 27, 2019, 02:49:09 am »
Yes, this
is
a "probe problem."
A 50Ω cable, attached to a 50Ω signal generator output, must be terminated with 50Ω at the scope end.
Basic transmission line theory.
RF+ Tech
Logged
RT-1133 AN/PRC-70 * RT-794 AN/PRC-74 * RT-841 AN/PRC-77 * RT-524 AN/VRC-12 * RT-834 AN/GRC-106 * RT-F100
guy232
belzrebuth
Country:
Reply #4 on:
September 27, 2019, 09:19:00 am »
This is not the issue here I'm afraid.
The problem persists even If I terminate the bnc.
I will go through the adjustment procedure up I think.
Something I've noticed is that when I'm in the mV range the squares look infinitely better than when I'm in the volt range.
The calibration steps for the square wave are also in the mV range..
But my problem manifests in the volt range.
Logged
2N3055
Super Contributor
Country:
Reply #5 on:
September 27, 2019, 09:31:04 am »
You need to put additional 50ohm terminator resistor on scope side when using BNC cable. Your scope is 1 MOhm input..
Logged
Dr. Richard W. Hamming
shakalnokturn
Super Contributor
Country:
Reply #6 on:
September 27, 2019, 11:48:39 am »
After replying to the other post, I started thinking: If both channels were wrong in the same way, any chance it is the vertical amplifier frequency response that needed readjusting rather than input amplifiers?
I haven't looked at the S.M.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
