If it's not present in the higher frequency bands (above 3.something GHz), then it's probably one of the stages on the 3GHz board - and if it's localized to one area on the 3GHz board, it could be localized to one of the filter paths. Does it show as output unleveled while the error is showing?
If the power is varying slowly, or in an analog manner, it's not going to be the mechanical attenuator. That can still leave the electronic attenuators, but those should be in the ALC loop, so the output should show as unleveled if that's the case.
