I am back with some results :-)
At the end is scan with measured voltages.
I have noticed something today that I overlooked. No matter if scope is cold or warmed up, when I power on the scope with RO intensity turned full ccw this gosting effect is present till I turn RO Int slightly cw and then back - then it dissappear. Difference is that on cold startup i doesn't do the trick. Ghosting is present till scope warms up and I Use RO intensity the way I explained before.
See video (actually i captured one of very rare situations when after restart with ro intensity turned ccw, there was no ghosting effect (usually it is almost always like on first start on this vid.)
. Those was restarts after warm up.
https://photos.app.goo.gl/oeVBXWVrw1xtBbCL6In case we missunderstood of ghosting effect.
Normally on this scope when RO intensity is turned up there is a matrix of dots generated with readout and readouts are displayed sharp with no blurr around and no flickering. In my case matrix of dots shakes and are blurry + they are running from lef to right of crt and readouts have blurr also, and are slightly dancing around + flickering.
Voltages goes smoothly from 3,8 to -3,8 and also from 2,5 to -2,5.
No sudden change on pin 8
At mechanical center of RO int voltages are near zero V.
I run out of cold spray - must order. Heating with hotair shorten time needed to make ghosting dissappear. U1001 during operation i s normally cold. U602 gets warm approx +50 degrees celcius (122 F).
U600 is also cold as cucumber :-) Maybe slightly warm.
I am slowly suspecting U602 is going bad. What should I check also to rule out or confirm U602 fault?
Edit:
Look what I found today:
https://photos.app.goo.gl/RPQQkWBhBpVKKWdGADS2704 is glowing. I am pretty shure it didn't before. When I turn focus up it is glowing brighter. When down it dimms.
New problem or indication of problem that already was there? :-) This scope will kill me. :-)
