Next thing, check for Vbb3, from U604 pin 11. U604 is an ECL device, MC10116. From the datasheet, Vbb should be 1.25 to 1.35 Vdc less than Vcc2 on pin 16. Referring to your annotated schematic, Vbb3 connects to the left end of CR1005, just above the red +4.5 annotation.
Beyond this, all of the logic inputs to the left side of U602 should be checked, to determine how much U602 functionality is actually operational or impaired. Does Beam Find or Bandwidth Limit work?
I've seen corrosion damage caused by battery electrolyte leakage, on at least one 2246. Both cell holders were trashed, several tracks and a section of ground plane eaten away and multiple through-hole parts damaged.
RF+ Tech
