Welcome to the forum.
I read your service log, not bad, shame I can't say the same for your repair.
Better you find a suitable replacement cap, get a few if the scope has more, and make a tidy repair that you can be proud of. Long component leads in test gear are to be avoided. You probably used too hot a setting for the soldering iron to lift the pads like that. More practice required.
C108, C108, C108.......... add it to your OP.
