I have watched your videos and process and I can’t agree with the long term viability. Reviews, fine. I don’t get any negative feedback even if I don’t successfully fix something. I’m paid to throw a life ring out.
There is a difference between a bad review for something not being fixable and a bad review because something broke repeatedly months later. The former, you would have to be a real douche to leave. The latter would be common.
The problem with the bodge wires is that they affect both mechanical and electrical reliability. For example if you look at bus lines, relflections and termination are important. Fundamentally that alters the characteristics and the designed in parameters such as trace length. While the general case may appear to work in he short term, mechanical stress caused by expansion and contraction on a solder joint can kill it dead again. Even if you anchor, epoxy it afterwards it will fail and fail quicker than the rest of the board. On top of that if it screws a bus transaction 1 in a million times, is the user going to notice their data getting hosed? Not until something crashes. Not like the machines have ECC in them. If you’re reworking power, less important.
That we are even discussing ECC shows how convoluted this conversation has become. We have to differentiate lines. We're not advocating for a 9" bodge wire being run from the memory to the CPU. We're talking about a 0.05mm wire being run for LCD power feedback or current sensing, which is not going to have any practical affect throughout the usable lifetime of the device. Further, you are welcome to drop any board with this wire on it off a building and check the joint's continuity when dropped.
If we were soldering 22 awg speaker wire to a 0201 resistor, fine. But 50 awg magnet wire on a 0603 with a good joint is sticking on there just as fine as the rest of the board.
My reputation comes from reworking and QA’ing milspec flight hardware for a defence contractor. Not something I can demonstrate publicly really unfortunately. That stuff was designed to be reworked though, not shitcanned like most consumer electronics. The parts that were disposable usually blew up intentionally.
This honestly doesn't surprise me. One of the people that taught me much of what I use today as a diagnostic mindset, used to shoo away any idea of modern repair.
"that surface mount stuff isn't made to be fixable, and it's too damn small!" This seems to be a common attitude amongst people who are used to working on devices that were designed to be worked on, and it is totally understandable -
"I spent my career working on devices where the manufacturer helps you repair them. Now they are designed intentionally to NOT be repairable - "fuck that!" I get it, but if i had listened to many of these naysayers I might actually BELIEVE that board repairs failed because of bodge wires.
Most things that come back for warranty are because a CPU mosfet flinched and sent too long a spike of 12v to a CPU, which was part of the initial damage. This has nothing to do with bodge wires, or signals "stopping short" 1 in 100k times due to a wire. These are the devices we deem unfixable from the get go. If a high side MOSFET going to a microprocessor is destroyed, it's probably going into a bin, not worth the hassle for us or the end consumer.
Edit: you can see this just by walking down a street. Everyone you see with a smashed phone screen. Think about why it’s still smashed.
Fixing your phone is a chore. You have to find someone trustworthy, make a trip out of your way, wait in line, etc. A cracked screen if the image is still visible, to many, is not worth adding it to their chores list. Same reason people don't go to the gym two weeks after New Year's.
