Author Topic: Replacement IC  (Read 3449 times)
Offline Tony.TTopic starter
  • I want to live in theory, everything works there!
Replacement IC
« on: September 30, 2017, 08:45:20 am »
I have a broken USB charger for car.
The IC chip does not give out 5V ..just 0.5V
The IC is HC1005 (HW) EF6V4R   12V to 5V step converter.
I tried to find it on ebay but no success
http://img.hqew.com/File/Images/230000-239999/239027/Electronic/2017614104616590641.png
http://product.hqew.com/26437088.html
I do not understand Chinese  :-).
Is there anybodu out there that can point out a replacement IC with same pinout as this one?
Thanks a lot in advance...
Offline Armadillo
Re: Replacement IC
« Reply #1 on: September 30, 2017, 09:44:42 am »
Try AD84064Q.
or 34063A
Edit : or AD85063
« Last Edit: September 30, 2017, 10:44:20 am by Armadillo »
The following users thanked this post: Tony.T
Offline chhrisedwards
Re: Replacement IC
« Reply #2 on: November 27, 2017, 01:31:43 pm »
You can try this MAX756. It accepts a positive input voltage down to 0.7V and converts it to a higher pin selectable output voltage of 5V (or 3.3V).
Offline james_s
Re: Replacement IC
« Reply #3 on: December 02, 2017, 12:17:05 am »
I'm all for repairing things, but is there something special about this USB charger that makes it worth buying replacement parts when you can buy a whole unit for a few dollars?
