Hello to everyone, I'm sorry to do my first post about a repair question
First to all, forgive me for my bad English
I'm trying to repair an old macintosh plus:
I got it with a really common problem, a blown up main filter capacitor.
I have replaced it, cleaned the board, checked for spread metal. I also checked the capacitors in the power board, due the ones near the filter capacitor gets some scratch.
According to various manuals found online I checked the voltages, 5V, 12V , -12V on the power board before reconnect the logic board, and after I checked them again on the external drive connector.
Everything seems ok, but the macintosh refuse to start up. I only got an infinite loop of initial bong! And a black screen.
At this point I’ve tried a lot of checks, but everything looks good, the caps on the logic board are ok, I also cleaned all the socketed ICs, the SIMMs pins and all the other connectors. I also resoldered the connectors on the power and the logic board.
The only thing I got are some raster lines, increasing the luminosity trimmer on the back of the power board.
The black screen issue seems related to the power board, but I also got a infinite Bong! from the logic board. So I decided to check if some video signal was generated from the logic board. And this is what I got:
Channel 1 is the video singal, CH2 Hsync and CH3 Vsync.
The Vsync and Hsync signals are ok, and I got some starts of video signal on the power up, then nothing. If the black screen was caused by a logic board fault, the power board can be ok.
For a double check I powered up the logic board with an external PSU and the result was the same.
I also checked the speaker line and i got the same eternal bong pattern.
So the logic board issue is not related to the power board. At this point I checked for a possible cause of the eternal Bong! the first thing I thought was to some reset problem.
And after a lot of tests I finally got this:
There is really some reset issue, for some reason the reset signal periodically falls and the machine never start up.
I looked the schematics in search of some possible issue. I don't understand exactly how the reset is implemented, but I supposed the SND chip is the one who generate the reset signal. When the reset switch SW2 is pressed, the pin 6 of the SND chip read the voltage drop and put the pin 5 to low. I suppose
Anyway the problem must be generated somewhere on the reset line, so, the guilty must be one of the chips on the line, the SND chip, the U2A filter, or one of the other chip.
For practical reasons I started with the SND chip. I checked the pin 6 in search of some fluctuation of the input, but there wasn't. The problem don't seem to came from this path.
So I decided to lift the pin 5 of the SND chip, leaving the reset line pulled up to 5V by the R35. In this way I got some strange sound instead of a classic Bong, perhaps due to the fluctuating pin 5? So I decided to remove the SND chip, because according to the schematics it does not seem to do anything special, except managing the reset.
In this way I got some video signal
But the screen is still black
I also got some strange segmented line instead of a single line as before.
I'm very confused.
I can't understand what kind of problem I have here. And I can't find anything specific for the logic board troubleshooting. The only information I got are mainly related to the power board.
I hope someone with more skills and experience than me can help in this case.
Thanks to everyone, and sorry for the long and not easy readable post
