Hello everyone.
I acquired an old Tektronix 2792 spectrum analyser. It was very cheap. For what I can see, it works fine and measurements are accurate. I will have to run more tests and probably have it calibrated but for now I didn't want to let it work too long without working on the power supply first.
So I want to change all the electrolytic capacitors on the power supply as well as the Rifa safety caps (X and Y class). I have a problem though, I can't figure out how to open the unit. There are those rubber feet on the top and the bottom with a screw in the middle but it doesn't seem like they allow the unit to open. At the back, there is those two big rubber feet with two big and long screws but once the screws are removed, the feet barely move at all. I didn't want to apply too much force to avoid breaking anything.
I was wondering if anyone knows or have an idea how to crack this thing open.
