Author Topic: Tektronix 4051 screen filter / protector cracked  (Read 625 times)
Offline XenonTopic starter
« on: September 19, 2021, 09:08:25 am »
Hello all,
Currently I am repairing a Tektronix 4051 for the Dutch Homecomputermuseum. It is in terrible condition and I hope I can get it working again.
After powering it up (yes, checked the voltages first) I heard a klicking noise and smelled something burning. It appeared that a 5kV capacitor was arcing short (cracked). As soon as that is replaced I can test the rest.
The green-ish filter in front of the tube is cracked. It seems like ordinary layered glass, but there is something special about it.
On the back it has a metal coating on the top and bottom edge, and aluminum/aluminium tape at the corners. The pieces of tape push against springs connected to chassis ground.
When held against the light you see a blue/red oily kind of glow on the back of the glass, like there is a special coating on it.
Does anybody know if it can be replaced by ordinary green-ish glass, or does this coating have a special function for the tube to function properly? Or is it just shielding to protect the user from tube emissions?
« Last Edit: September 19, 2021, 09:39:17 am by Xenon »
Offline David Hess
  • DavidH
Re: Tektronix 4051 screen filter / protector cracked
« Reply #1 on: September 19, 2021, 07:51:32 pm »
My guess is that is EMI shielding.  On many Tektronix instruments EMI shielding, which included a metal screen over the CRT, was an option.
It it is not necessary for proper functioning so the CRT shield can be replaced with one that lacks the shielding.
The following users thanked this post: Xenon
Offline YetAnotherTechie
  • Country: pt
« Reply #2 on: September 20, 2021, 11:08:09 pm »
Have a look under a magnifier to see if there is a mesh inside.
Offline james_s
« Reply #3 on: September 21, 2021, 12:11:27 am »
I'm only speculating but I would guess it's an anti-reflective coating to prevent a "hall of mirrors" effect from light reflecting off the glass and back off the face of the CRT. The EMI shielding is another good guess, it could even be both.
I think plain glass or even acrylic would probably work fine, especially for museum duty. Certainly it would be better than the smashed glass.
