Hello,
I recently bought a Tektronix 464 Oscilloscope and I think it makes a rather good screen for my computer, as you can see in the image attached.
But there is one serious issue: The horizontal time deflection switch does not work properly in every position. Especially on the slow setting (high time per division that is) it only works when the knob is pushed to the right of the instrument.
Suspecting the switch contacts, i disassembled it, as depicted by an illustration of fellow member xtoffer below, and cleaned each contact with isopropanol. Still the issue persists though the switches visually seem to make contact. Do you have an idea what I could check next or is this fault common to you?
Assembling the knob on the shaft was a kind of trial and error... do you have a hint how to do this properly?
Thank you in advance.
Cheers,
mldevw
