Can someone please point me in the right direction?
I am repairing a Tek 465 that had several problems. So far I have rebuilt the power supply with all new capacitors, a new bridge rectifier and 3 new transistors. All voltages are now as expected with low ripple. I then repaired an issue with A trigger not working.
Now I am am stumped by an issue with channel 2 vertical. I assume its a vertical issue because its missing about 50% of its amplitude and the square wave is ramping. I initially assumed it had to be part of these circuits since the problem is only on channel 2 however I can find zero issues on the Vertical Preamp board or Vertical Switching. Its originating somewhere else.
Someone has attempted repairs on the scope before me and they were ham fisted. The delay line was roughed up and had to be soldered to the vertical preamp board. I cleaned this up the best I could and Im not sure if it had anything to do with my problem, I dont see how it could affect anything.
https://groups.io/g/TekScopes/photo/253550/0?p=Created,,,20,2,0,0I will cross post to the TekScopes group to get some other eyes on it as well.
