Author Topic: Tektronix 465 Oscilloscope  (Read 2557 times)
Offline j@csTopic starter
  • Country: br
  • If the led is on, it's soul is about to reveal ...
« on: November 04, 2017, 09:38:33 pm »
Hi, I have recently buy a 465 in good conditions but it`s front panel is quite a bit dirty. When I tried to remove the buttons to clear it, I couldn`t remove the delay time button and also that one that you have to pull to limit the bandwidth.
The delay time button is a bit complex and I`m afraid to damage it without any tips. And regarding to the BW limit button I`m afraid to pull it hard and break something. Does anyone there can give me some tips or even post some photos, if there are any, to help me?
Thanks guys.
Offline ebclr
Re: Tektronix 465 Oscilloscope
« Reply #1 on: November 04, 2017, 10:09:35 pm »
The following users thanked this post: j@cs
  • Country: br
« Reply #2 on: November 12, 2017, 07:34:56 pm »
ebclr, thanks for sharing the manual. Actually my oscilloscope is the Tektronix 465. Not the TAS 465. I am attaching a image it`s front panel.
Offline rhb
« Reply #3 on: November 16, 2017, 12:51:28 am »
  • Country: br
« Reply #4 on: November 16, 2017, 09:36:55 pm »
Thanks for the tip rhb.
I visited the link and downloaded the manual. But it is incomplete and didn't show how to disassemble the front panel.
« Reply #5 on: November 16, 2017, 09:47:27 pm »
I’ve done a few of these. To remove the delay time knob, there is a grub screw on the top half of the knob. Undo that. It will slide off. Under that is the main body of the vernier control. You need some long needle nose pliers to unscrew the big ring around the shaft. Whole thing will come off the front panel then. Watch out because the pot can fall inside the case. The rest of the controls are straightforward.
Don’t take the buttons off if you can help it. The shafts break easily. Just push in, clean, pull out, clean. Contacts for the bandwidth limit are at the opposite end of the scope to the button to give you an idea how complicated they are to get out!
The bulb indicator shafts pull out and can just be pushed back in after.
« Last Edit: November 16, 2017, 09:49:24 pm by bd139 »
Offline rhb
« Reply #6 on: November 17, 2017, 03:17:57 pm »
I looked at my original manual and there's very little discussion about disassembly.  No mention at all about the front panel.
Offline m3vuv
« Reply #7 on: November 29, 2021, 01:35:38 am »
sorted,i didnt see the slot in the outer where it unscrews,used a pair of circlip pliers on it,came undone easy.
