Hi!
The usual cause of E.H.T. failure of in these oscilloscopes is due to internal failure of the diodes in the multiplier module, and disconnecting the multiplier from the transformer will prove the point – you will still get a very faint hazy display on the CRT even without the 14 kV p.d.a. voltage !
There is a number of threads on this Forum that discuss these multipliers, including how to rebuild one !
You can test the transformer out of circuit if you have a signal or function generator!
Remove the transformer from the board OR unplug the base connector from the CRT. Also disconnect the E.H.T. multiplier lead from the transformer.
Set the frequency of your function generator to about 50 kHz, sine wave output, then connect it's 50 Ω output across the socket pins 1 and 14 of the CRT socket and gradually increase the output from zero.
Monitor the voltage across TP 1423 (–2450 V) with a digital multimeter as you increase the generator output – you won't be able to get anything like the full –2450 V as the generator won't be able to provide the full voltage generated by the oscillator transistor Q1418, but you should be able to get at least a few hundred volts!
I think there's a pdf data sheet you can refer to :–
http://w140.com/Transformers_120-0500-00_to_120-0998-01.pdfPage 260 of this pdf gives you all the information you need – if you can remove the transformer from the PCB, about 0.5 V RMS across the heater winding at 50 kHz should give you about 13–15 V across the 0–150 V tap and about 200 V across the whole secondary !
. . .And one of these transformers is available from QService in Rhodes (Greece) on their eBay listing pages when I wrote this!
If you find the transformer is providing negligible output from a function generator connected as suggested, there could be short–circuited turns in the e.h.t. winding!
If you need a replacement, try asking on "Buy/Sell/Wanted" for p/n 120–0800–00, or if there's anybody who can rewind transformers reasonably accessible to you in your country, you might be able to get someone who can rewind it from the old transformer and a printout of the "120–0800–00" pdf I linked !
Good Luck !
Chris Williams
