I'm really not sure where to start on this board. I measured most of the large ceramic capacitors, none were shorted, and the same with most of the obvious mosfets.
When I power it on, the keyboard backlight cycles on and off, and the fans run. No beeps, no video. I've got TWO machines. My original core i5 model which worked but got killed by a charging incident, and my core i7 nvidia GPU model which I recieved dead (note I did not buy these machines working)
The core i5 model is completely dead, I'm not going to try fixing it. It can be a donor board for parts though, but the core i7 nvidia model has more components due to a dedicated graphics chip.
Where should I start? Perhaps measuring the CPU and GPU core voltages?
It does beep without ram installed, so something's working
