Author Topic: Tektronix 465 - Vertical Deflection  (Read 797 times)
Offline kc4iTopic starter
« on: August 20, 2024, 09:53:12 pm »
Hello Forum.
I have a Tektronix 465 which I want to fix.  I have been using it almost daily since 1998.  Several weeks ago I powered it on and the vertical deflection was gone.  If I press the beam finder, a horizontal trace will appear on screen, about a quarter inch above center.  The up-down adjustment will not bring that trace into the visible area of the screen.
Any advice that would help in diagnosing and repairing this problem would be appreciated very much.  Thanks in advance.
Henry
« Last Edit: August 21, 2024, 07:01:12 am by kc4i »
Offline andrewtaylor
Re: Tektronix 465 - Vertical Deflection
« Reply #1 on: August 21, 2024, 08:26:59 am »
I recommend the 465 service manual with the "fault search tree diagramm".
If you have this,
the very first step is to check ALL voltages on the main PCB (+50V. +15, -15V. 8V etc.) --- with the age of the scope, it's the point to start with  ;D
The following users thanked this post: kc4i
Offline bborisov567
  • Country: bg
« Reply #2 on: August 21, 2024, 11:43:03 am »
You can take a look at that video: It is for 475 but i believe it might be helpful. Also if you have a transistor tester i would strongly recommend checking the transistors around the vertical deflection circuit. You can also find the service manual at the Tekwiki.
« Reply #3 on: August 23, 2024, 07:14:48 pm »
Mr. Taylor and Mr. Borisov,
Thank you kindly for the advice.  I will pursue those ideas and see where it goes.  I appreciate your knowledge and help very much.
Henry Fisher
