Author Topic: Tektronix 468 B sweep unblank or enable issue  (Read 7889 times)
Offline Addicted2AnalogTekTopic starter
« on: January 24, 2016, 05:04:10 am »
I am currently working on calibrating a Tek 468 that I fully restored and have run across an issue that I haven't yet been able to resolve.  The B sweep isn't unblanking at the same point as the A sweep (as seen in photos) and no settings or adjustments have any effect on it.  I tried all the timebase settings and triggering settings and believe I have isolated it to the horizontal sweep logic.
I have been going through and attempting to see if all of the A/B sweep waveforms from the manual are lining up with each other correctly with the clock pulses, and haven't yet found anything unusual, yet....
I have another 468 that isn't fully restored but is functioning correctly in reference to this manner which I am using to compare against.
In the pictures, I am running a 1ms time mark pulse from a Tek 184 into both scopes via 50ohm terminator and tee.  Both externally triggered (not that it matters for this).
Any ideas??
http://www.ebaman.com/index.php/remository/ELECTRONICS/Test-Equipment/Tektronix/Scopes/4XX-series/Tektronix-468-Vol2/
http://elektrotanya.com/tektronix_468_volume2.pdf/download.html
Re: Tektronix 468 B sweep unblank or enable issue
« Reply #1 on: January 24, 2016, 02:32:54 pm »
Re-reading the theory of operation section is giving me some fresh ideas on where to look and what to look for.   Forgive my lack of understanding and knowledge about circuit functions as I am still trying to learn much of the operation of various circuits..  it's quite a journey so far, but once it all "clicks" in my mind and I become able to visualize everything, things will become clear and fairly simple.
Offline MrSlack
« Reply #2 on: January 24, 2016, 02:59:22 pm »
Had similar issues on my first 465B. There was a bad diode in the delay sweep if I remember (may be wrong, it was 8 years ago) which left it sort of half working. Took me a month to find it!
« Reply #3 on: January 24, 2016, 03:04:04 pm »
Fantastic!  You have just confirmed my suspicions!  After reading the trigger, sweep, and z-axis sections of the theory of operation I had the idea that maybe there is a diode that is not switching properly.  Considering the circuit actually functions and this is the only problem, I felt that it is unlikely to be a transistor or the sweep IC.    Now to find the bugger....
Offline MrSlack
« Reply #4 on: January 24, 2016, 03:08:26 pm »
Good luck :)
« Reply #5 on: January 24, 2016, 03:33:05 pm »
It's one of these guys in between test point 66 and test point 67.  (just as a quick update and for anyone wanting to take a guess....)
Offline MrSlack
« Reply #6 on: January 24, 2016, 03:35:13 pm »
Looks about right. Check that FET as well. Every damn Tek I've had eats them.
« Reply #7 on: January 24, 2016, 03:52:26 pm »
There is a 800us delay between the charging of the A timing capacitor and the B timing capacitor.
Unfortunately all of the sockets have been removed and the components soldered into place on this specific scope, so I am going to attempt to completely isolate the issue as best as possible before swapping parts.
« Last Edit: January 24, 2016, 03:54:39 pm by Addicted2AnalogTek »
Offline MrSlack
« Reply #8 on: January 24, 2016, 04:05:13 pm »
That's a dick move by whoever removed the sockets. Might be an ex military one though;  they tend to be 'replace entire subassembly' mentality when something goes pop and require slightly better mechanical stability.
« Reply #9 on: January 24, 2016, 04:12:50 pm »
If I remember correctly, this one came out of a GE lab.  It's in far too good of condition to be ex-military, though.
« Last Edit: January 24, 2016, 04:18:04 pm by Addicted2AnalogTek »
« Reply #10 on: January 24, 2016, 05:47:49 pm »
Do you think that it's possible the problem lies within the A sweep circuitry?  I have tested/swapped the fet, Q967, Q864, and all of the diodes in the "problem area"... however, my only indication I have found to go on is the 800uS delay between the start of the timing capacitor charging.   I wish I understood circuitry better already!!
Offline MrSlack
« Reply #11 on: January 24, 2016, 06:09:07 pm »
Is there any difference if you select horizontal mode of A only, turn both channels on and onto GND and use horiz position to set the left of both channels mid screen? Leave triggering on NORM across the board. Also when in X-Y mode does the dot stay still if both channels are grounded?
« Reply #12 on: January 24, 2016, 06:14:49 pm »
The issue is only with B sweep.  CH1 and CH2 traces both have the same start point if I have only the A sweep selected.   XY mode functions normally and the dot stays in position when switching CH1/CH2 between input coupling settings & ground.   It's only when I display the B sweep that anything becomes apparently wrong.  No matter what the settings on anything are, the B sweep starts one minor division after the A sweep.
What I was thinking about in my other post regarding the possibility of the issue being in the A sweep circuitry, is that if A sweep was actually starting too soon and B sweep was the correct one.
« Last Edit: January 24, 2016, 06:23:08 pm by Addicted2AnalogTek »
« Reply #13 on: January 24, 2016, 06:20:23 pm »
Also, I am mostly using the manual specified settings for the logic waveform comparisons that I am making.  every once in a while I will input a signal and compare the two scopes against each other, and also the A and B sweeps against each other.      I will eventually track this turd down................
« Reply #14 on: January 24, 2016, 06:30:31 pm »
I'm going to take a look into the B sweep / Z axis unblanking signal area and see if I can find any discrepancies..
« Reply #15 on: January 24, 2016, 07:01:03 pm »
I may be correct in thinking that it is an issue with the A sweep and not the B sweep.   When comparing the two 468s in horizontal ALT mode, DTP=0, the A sweep on the problem scope starts 1 minor division before DTP=0  ( there is 1 minor division of lower intensity at the beginning of A sweep with the delay time position control at 0 )   This is not the case on the other scope, where bringing the DTP control to 0 completely eliminates all of the un-intensified portion of the trace.
Offline MrSlack
« Reply #16 on: January 24, 2016, 07:12:34 pm »
Ok I can't shed any more light on that here. Blanking didn't work at all on my second 465b but that was a relatively easy to find out of tolerance resistor.
« Reply #17 on: January 25, 2016, 09:07:37 pm »
from what I am gathering thus far, it appears to be the timing capacitors or something else on the timing board. All of the test point signals line up with the horizonal alt sync pulse on both A and B sweep circuits only before the signal passes through the timing board. After the timing board, both A and B sweep signals are out of sync with the alt sync pulse.
Offline MrSlack
« Reply #18 on: January 25, 2016, 09:31:21 pm »
Has to be something around the unblanking diodes. Can only thing that you're going to have to trace it component by component to where it barfs :(
« Reply #19 on: January 25, 2016, 09:48:07 pm »
Well.... while poking around test points to see what matches up and has the correct waveforms and what does not, I managed to find a very unhappy B Trig Holdoff/Reset signal.  1V/div with baseline at 2nd from bottom.  Compared to A sweep fast blanking signal.   I know it's unrelated to the issue at hand, but it's something that the trigger IC must not be very happy about as well as something that should not be.
Correct signal should be -0.9V to +1.2V fairly clean square wave.
« Reply #20 on: January 25, 2016, 09:54:42 pm »
im about to break down and just buy the volume 2 manual or at the very least the artek cd manuals.  the part numbers on these printouts are total junk.  I suppose I have no choice but to deal for now though.
Offline MrSlack
« Reply #21 on: January 25, 2016, 10:13:49 pm »
the Tek 465B AFAIK is the same on the analog side of things. Service manual is here: http://www.opweb.de/en/model.php?id=2650
Much better quality than the other copies and is actually complete.
« Reply #22 on: January 25, 2016, 10:18:17 pm »
Awesome, thanks!   As for my last post regarding that odd B trig holdoff signal.. it's the same on the other scope.   I have to stop letting myself get sidetracked. I'm sure it's irritating for anyone following along and especially you attempting to help out. So, sorry for that!
Offline MrSlack
« Reply #23 on: January 25, 2016, 10:21:06 pm »
I do that so many times. I do software as a day job and I'll spend all day fixing something that isn't wrong. This is part and parcel of debugging and fixing things. It's always valuable though as you get to understand what you're fixing more every time :)
« Reply #24 on: January 25, 2016, 10:26:06 pm »
When comparing test points against the A sweep fast blanking signal, the only one that does not match up is test point 58, which is the same as test point 68 from the sweep generator schematic. Right back into the area that you stated "seems about right"... so time to stray from the test points to really get it isolated....
