It has come to my hands an scope with so many years in st-by. It is a Tektronix 475 is in very good condition but has several problems.
Necessary repairs in the power supply have been performed successfully, but there is a problem with one of the channels (2).
The problem is that the vertical knob does not work. As time goes up the trace to get lost in the top of the screen.
It's like there DC voltage at the amplifier channel 2.
I have removed the first amplifier IC, and trace can view and move perfectly. Thinking that the problem could be the amplifier IC, I've exchanged. But the result is the same, I have
also disconnected the resistance goes (solder aerially) to one of the pins of the IC (I guess that is the entrance). But still unsuccessful.
In a quick check the voltages, I have seen are all correct and identical to the channel that works well.
I rule out a problem in the power section of the vertical deflection, when removing the IC amplifier channel 2, the vertical knob responds perfectly.
Any ideas or suggestions?
They will be very well received
See video...
http://youtu.be/DMu_bnzYmv0Sorry for bad my english.
Best regards,
