I have just brought my first analog scope, a Tek 475A! The scope has a slope switch to select trigger on raising edge (positive slope) or falling edge (negative slope). However, on cold startups (e.g. early morning), the trigger fires on both raising and falling edges regardless of the slope switch. After running for a 15 minutes, the scope would work properly and trigger according to the slope switch setting.
Any idea how to fix this? Is it normal to warm up these analog scope before use?
I've attached a picture of my scope with an input from a function generator into ch2. The slope switch is set to positive slope (green oval). However, notice I am getting 2 traces with both positive and negative slope. The scope is firing on both positive and negative slope of the input signal.
Thanks
