Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
tektronix 540 navram options firm 2.00 possible upgrade to higher levels
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: tektronix 540 navram options firm 2.00 possible upgrade to higher levels (Read 638 times)
Tektronix 540 (rotto)
Newbie
Country:
on:
August 01, 2021, 06:09:02 am »
tektronix 540 navram options firm 2.00 possible upgrade to higher levels; I replaced the capacitors and navram and installed the vers. 2F_13, but I had errors; later I was able to reprogram the same files in the old navram and now I have only error related to port 232 which is not installed.
if anyone help me now i have the following problem even if i update the system date the next day i find that the date has not passed to the next day.
Also I'd like to upgrade its current capability to some superior features; if this is possible I have read several posts but obviously I would like some advice to proceed in the most correct way.
Also available to replace the cpu card with a higher-end one
Logged
Newbie
Country:
Re: tektronix 540 navram options firm 2.00 possible upgrade to higher levels
Reply #1 on:
August 01, 2021, 06:13:08 am »
I add the photos of this latest update after rewriting the files in the old navram errors have been removed; but I am left with this flaw in the update date
Logged
Newbie
Country:
Reply #2 on:
August 01, 2021, 06:23:50 am »
I am attaching photos for your help
Logged
picburner
Frequent Contributor
Country:
Reply #3 on:
August 02, 2021, 07:13:16 am »
Regarding the issue of keeping the date:
The TDS540 doesn't have an RTC, so it is normal for it to lose the day and time, U1107 is a 128Kx8 SRAM only.
Moreover this fact is specified in the user manual pag. 106 (chapter 3-44).
Logged
Newbie
Country:
Reply #4 on:
August 02, 2021, 12:40:59 pm »
I have programmed a new navram and I have also removed option 13 so I have no more errors, but the date error remains. i think i could go deeper around the nav because there are jumpers that i might have to close like pc
Logged
Newbie
Country:
Reply #5 on:
August 02, 2021, 12:43:51 pm »
then if this is not a step forward, I have to buy a 500 Mhz probe what checks can I do to understand that it works perfectly
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
