I'd definitely like to get some feedback on my troubleshooting here.
I ran through every node in the power supply unit with a voltage callout and put it onto a print of the schematic for the DC supplies.
Red measured not to specification, yellow was unknown due to me not seeing a callout on the print for that specific node. Green measured correct, blue circles on the left where green turns to yellow or red.
My suspicion is that one or more diodes failed for the -150V section, and by my understanding of the power supply, the -150V is used to regulate the other supplies and can be adjusted, unlike the other supplies.
I checked R640 and R641 and didn't see anything that seemed exceptionally unusual for their resistance, and when I checked in circuit the +90 node after them measured at 3.9V and before them measured 4V, from what should be 208Vrms rectified.
I could be wrong and overlooking something with my 0V reference as my understanding is all the DC voltages are measured relative to ground, but I think one or more of D642 has failed.
First, am I way off on my narrowing down?
Secondly, all I can find is it's a Tek part # 152-047 which seems to be a Fairchild FD700 as one replacement as they seem to share the same NSN, but is there a specific list of replacement semiconductors for Tek part numbers using more modern equivalents that I am just not finding?
Or is it more of a non-special component where one of the same current and voltage characteristics would be good enough?
