Rebonjour Cher monsieur Johnnie
As power electronics designer, consultant and manufacturing in 1970s..1990s, we used both 577 and 576 Tektronix extensively. Tested 20,000 150V HV Zener diodes for production avionics power supply.
Very lucky to find these curve tracers in 1980s, in excellent condition with test fixtures and front porch 100A pulsed, programmable and regular. At Silicon Valley ham radio Fleas and auctions.
1. use 99% or 91 % isopropyl alcohol to clean test equipment knobs, panel's, PCBs, etc. Very low risk of damage
2.please DO NOT use WD40, petroleum distillates, or powerful organic solvent like acetone, trichlorethene, etc severe damage to plastic, components etc.
3. Many forum vintage equipment folk are afficanados of Craig Deoxit products for controls and pots.
4. We have managed for decades to use ordinary TV tuner cleaner, control lube etc. from Miller Stephenson, GC, etc. Some tektronix equipment have sealed square blue Bourne pots, more difficult to clean.
5. Additional common failures of 576 to beware of are the deteriorated plastic on certain knobs and controls, e.g. the small top row focus, intensity controls.
Also, especially delicate are the main large control knobs for mode, R/ power/Voltage range, etc.
Very easy to split knob at sets screw and nearly impossible to repair or to find replacement knobs. ROTATE LARGE CONTROLS SLOWLY, and CAREFULLY!
6. Besides eevblog, best advice, parts, accessories on all Tektronix scopes and curve tracer at tekscopes2 and tekscopes @ groups.io, some veteran Tektronix engineering and technicians...Best information, manuals at W140 and Tekwiki.
7. Test fixtures are rare and costly, but DIY versions and PCBs are on both eevblog and tekscopes2
Our most used fixtures are TO3, TO247, TO220, diode 4 terminal, and TO92.
8. The high voltage safety cover is useless and easy to break. Most simply defeat the interlock switch at lower left of front porch.
Hope you enjoy my notes and tips...
Just the ramblings of an old retired EE (1968!)
Jon
