Hi i decided to open a new topic about the Martek Power because this PSU can be found in multiple equiptment from tektronix like TLA series and both first and second generation 7000 series
the Martek PS2251 - power supply. ( see attachment )
here is what i already did :
after i replaced all caps with value 68uF arround the transformers. and 4x 330uf in T7 circuit and all 1500uF in T10 and T7 circuit.
and all small caps in the T10 circuitry, i was at the point of powering on.
"TiN" is talking in one of his post about connecting loads on the output.
So i placed the psu on my bench. with the switch over J1/P1 and P4, where the past one is Ground/return.
to make thing s visible like this:
[J1] P5,6 --- 18 ohm --- gnd >>>>> +12v.
[J1] P11,12 --- 18 ohm --- gnd >>>>> +5v
[J1] P19 --- 18 ohm --- gnd >>>>> +3,3V
[J1} P1 --- __/ ___100ohm --- gnd >>>> power switch in series with 100Ohm.
my red led lit when switch is open , it goes of when #PS_ON to gnd.
but doesn t lit when the switch is toggled to power off again.
the secundairy side of the T7 circuitry has its own supplies for connector[ J2 ] which are not present +15v -15 v and no + and - 5 volts
Maybe i forgot to say but i already repaired my primary side.
Now i am tracing the secundairy side of these famous Martek PS2251 power supply and i am curious if anybody can add info like drawings / selfmade diagrams / hand made schematics from the T7 sec. T10 sec.
i am missing some voltages like. +5v -5v +15v and -15v located on J2.
besides in my test configuration my [J1-p5,6] +12 is not more then +5.94V but even with a 100% working psu which i had for compare this output was as low as 5.9-6.0v or so .
When i dive into this problem from a different side , my conclusion was lets try to disable the T7 circuitry by removing the F51 (5 amp) chipfuse and see if the psu is powering on now.
and yes it is... so it feels to me the problem lies in T7 secundairy side...
