med6753 that's neat. I'll bear those cap adapters in mind next time I'm in that situation.
Another thing to consider - if you're going to that much trouble to restore some old gear, why not also substitute an IEC socket/filter for the annoying hard-mounted mains cord. If there's room on the backpanel and space inside. Looks like there is on that unit.
Makes such an improvement.
My 7613 has an IEC socket as standard, but the Gorillas have been at it, with the lead to the fuse in the Neutral line, instead of the Active.
When the 'scope died, it also lost the +15v & +5v supplies, but I read somewhere that Q931 tended to fail.
Sure enough, it had, so I replaced it with the nearest spec transistor I could find.
Lazily, instead of tracing each connector & cable individually, I relied upon the pictures I had previously taken, & plugged them back in the "logical" places.
On turn on, I now only had -50v!!!
OK, time to stop being lazy, so I unplugged all the connections between the LV rectifier board & the regulator board.
Turned on again, --------zilch, not even the fan!
Started chasing through the LV rectifier PCB, found nothing on the fuse on the board--- what the heck?
Realised that was just an unconnected spare fuse, so rethought things, removed the screw in fuse---O/C.(it looked very old, so I think it was just a physical failure)
Replaced it with the spare, now all the rectifier outputs are OK.
At this point, I also realised the "gorrillaisation"which had been performed on the IEC .
Now it looks like, before I connect up the LV regulator, I will have to look at Q931 again, & also check those caps on the vert amp that
sean0118 found on his 7623.
I don't think (or, I hope), I have connected the -130v in the wrong way, or it would probably have killed the -50v as well.
The latter appeared in the right place, which is why I am optimistic.
