Hi, I have acquired a Tektronix 7904 for a fairly cheap price. I hope to restore it.
The scope is whole and is missing no parts to my knowledge. The mainframe has an early serial number (B0922#2) The hashtag means the digit is illegible. The red warranty sticker inside says the warranty expires in 1973. Tek usually has 1 year warranty so I think the scope was manufactured in 1972, near the very start when the 7904 scope was rolling out.
The insides are... not very clean. I see mud and A LOT of dust and particles. A spider even decided the scope was a good place to build its home.
Anyways, as for symptoms, the scope goes into "burst" mode, indicating a short somewhere.
All plug-ins have been removed
Resistance on voltage rails from Z-axis, chassis ground referenced show:
+130v ~ 6.63k ohms (bit high)
+50v ~ 314 ohms (low)
+15v ~ 7.4 ohms (very low)
+5v ~ 22.2 ohms (low? Not sure if it's lamp or not)
-15v ~ 84 ohms (low?)
-50v ~ 310 ohms (high?)
According to this:
https://w140.com/tekwiki/images/f/f0/Servicing_the_Tek_7904_Power_Supply.pdf journal, the expected resistances are:
+130v ~ 6k ohms
+50v ~ 2k ohms
+15v ~ 90 ohms
+5v
LAMP ~ 800 ohms
-15v ~ 100 ohms
-50v ~ 250 ohms
These are resistances with the PSU fully connected
Resistances with the PSU fully disconnected (except HV anode):
+130v ~ 7k ohms (high?)
+50v ~ 2.06k ohms
+5v ~ 40.7 ohms (lowish)
-15v ~ 192 ohms (high?)
-50v ~ 6.87k ohms (high)
Expected are:
+130v ~ 6.6k ohms
+50v ~ 2k ohms
+15v ~ 90 ohms
+5v ~ 65 ohms
-15v ~ 110 ohms
-50v ~ 2k ohms
+5v Lamp ~ open
With P1896 removed however the blue one in the photos of the Z-axis board, resistances are as follows:
+130v ~ 12.4k ohms
+50v ~ 12.7k ohms
+15v ~ 283k ohms (short cleared)
+5v ~ 1k ohms (short cleared?)
-15v ~ 1.8k ohms
-50v ~ 66.2k ohms
P1896 leads to the plug-in interface board, which is very difficult to access.
This is all I have for now. Unsure how to proceed. I'll try some stuff later.
The manual on Tekwiki has some schematics that are difficult to read. It is also meant for a high serial number scope. The one I have is low, unsure how helpful that manual is.
I do not have any proper formal education on electronics. I only have 4 years of YouTube, books, and self-learning. I have no school for this entire week so I plan this to be a project of mine.
I have experience with these scopes though, repairing a 7613 in the past (though only bad capacitors). I have a few oscilloscopes (Tek 2230, 7613, Hantek DSO2D15), and a 5CT1N curve tracer to check transistors if need be. I think I am quite well equipped, but lack the knowledge to make any proper guesses for problems.
I suspect tants shorted, as they are common. The schematics on Tekwiki, as previously mentioned, don't have crisp scans on some schematics, so I can't trace down P1869 very well.
