Hello I got this set up but the curves on the crt display are upside down and reversed .
What I m doing wrong?
I connect the horiz-vertical out to an 7b70 on amplifier mode on the horiz in.Also I connect this cable to channel 1 of the 7a18 amplifier with no results at all.
Also on the dc output of the 7ct1N never reaches the 300 v out like 160 c and the caution lamp goes on at approximate 40 volts,
I replace the 2 resistor of 240 ohms and the 2 50uf capacitors there where at 25 v,very originals.
The 2 180ohms 1watt resistor on the 30v supply are out of value like 220ohms and 300 ohms each but I dont think these are relevant at the moment.
Also with this modules there is no screen read out on the CRT is this normal?
Thanks for the help
