Hello, a few days ago I opened the device and at first glance there was nothing strange. I decided to remove the main board to review it. I found that it was as if some liquid had been spilled on the board. Then I gently soak and clean with isopropyl alcohol with the help of a small brush. I gave it several rinses and then let it dry. When observing the remains of the alcohol I noticed that at the bottom of the container there was a white sediment, I wonder what it would be?
Well, I have checked the card after a few days and I see that there are still traces of dirt, the board is not completely clean. I need to clean it even more.
To save time, I check the electrolytes with an esr meter and they are all ok. Although a few days ago a couple of them marked me in bad condition.
Locate the NV Ram this is the U32. This is a small square pcb board with 120 pins soldered to the main board, I wonder is it okay?
Also note that a regulator attached to its heatsink has the thermal paste spread out, as if it had been manipulated with fingers. But I don't see that the welds have been touched up. Besides, I found a small MS621FE battery, it has only 0.51v but I did not notice that any of it has spilled. It is necessary it to replace.
I don't see bad tracks or components.
And Well, it also seems that no one has tried to repair the board.
According to your experience, please, how could I check if the NV Ram works?
I will be grateful for any suggestions,
73! Rafael
