Electronics => Repair => Topic started by: hitecelec on July 23, 2019, 10:49:14 am
Hello All
what is the fuse rated voltage and type of fuse ie very fast acting/fast/slow of the 0.125Amps fuse
supplied with the fuse adapter 013-0345-00. the tek part of fuse is 159-0454-00. this adapter and fuse are supplied with tek AFG3021
thanks in advance
Regards
Anand
Specification for this Tek. Part No. (P.C.B. Mounted, Through-Hole with Axial Lead, Miniature Fuse) is nowhere to be found. This is the closest I could get, https://www.littelfuse.com/products/fuses/axial-radial-thru-hole-fuses/pico-fuses/251/251_125.aspx (https://www.littelfuse.com/products/fuses/axial-radial-thru-hole-fuses/pico-fuses/251/251_125.aspx)
It looks they should be Fast-Acting/Very-Fast-Acting & better to be used with Lower Voltage Rating (as they're supposed to Protect Output Stage of Tek AFG3021. 125V AC/DC @ .125A is the Voltage Rating for the Littlefuse 251 Series (PICO Fuse) I've linked above.).
Hello Dutta
Thanks for the assistance
Regards
Anand
